Page 8-42 Received Grove gear today Very nice! Leveled the fuselage inverted on sawhorses Match drilled the 7/16 hole in the inboard wear plate Installed the left and right U-801-L gear leg, U-804 inboard main gear attach bracket, U-806-1 inboard wear plate and U-805-1 outboard wear plate onto the fuselage using the 7/16 bolt nut and washer. Fitted the U-803 outboard gear attach brackets. Needed to file the rear crossmember for fit Inserted 3/8 bolt to maintain alignment in the U-803 outboard main gear attach bracket and U-805-1 outboard wear plate
New Grove Gear! Sweet!
Drilling the U-804 and U-804 main gear attach bracket and U806 wear plate
