Brief Description: Adding tailcone to fwd fuselage
Page 8-24 Deburred all openings and edges of the F-824 L and R-1 aft side skins, F-842-1 aft bottom skin and F-828-1 aft bottom skin Clecoed the F-889 lower longeron and F-888 mid longeron to the side skins Clecoed the F-807 bulkhead assembly in place Clecoed the F-818 L and R-1 baggage rib assemblies and final drilled #30 the 1/8 holes between the baggage rib and bulkhead assembly Clecoed the left and right aft side skins to the mid fuselage Clecoed the F808-1, F-809-1 and F-810-1 bulkheads in place. Final drilled #30 the 1/8 holes between the aft flange of the baggage ribs and F-808-1 bulkhead assembly
Page 8-25 Trimmed the notch for the tailwheel mount in the F828-1 aft bottom skin Clecoed the F-828-1 aft bottom skin on the F-811-1 bulkhead and F-812-1 bulkhead Clecoed the f-828-1 aft skin assembly to the F-824-1 aft side skins
