Page 8-23 Riveted the F-807 Bulkhead assembly parts together Trimmed, and deburred the F-818B-L-1 and R-1 Baggage rib angles Clecoed the F-818B-L-1 and R-1 rib angles to the F818-L-1 and R-1 baggage ribs and final drilled the #30 holes Clecoed and final drilled #40 the F818D-1 bellcrank rib to the F818-L-1 and R-1 ribs Final drilled and machile countersunk the platenut mounting hole Final drilled #12 the nutplate screw holes
Page 8-24 Deburred all of the holes in the F-818-L-1 and R-1 baggage rib angles and the F818-L-1 and R-1 baggage ribs Fabricated the F-857-L-1 and R-1 seat bealt brackets, deburred final drilled and primed the parts Rivetred the seat belt bracket parts together
Riveted the F-807 Bulkfead assembly together
Deburring the F-818-L-1 & R-1 Baggage ribs
Fabricating the F-857B-L-1 and R-1 Seatr Belt Brackets
