Completed drilling the attach brackets for the platenut rivets, deburred primed and riveted the platenuts on to the brackets. Bolted the angles in place, clecoed the T702 baffle to the T-712 attach angles. Backdrilled the attach angle through the spar. installed the nutplates on the aft side of the spar. Made the T-711 A-D stiffeners shown on DWG 16A clecoed them to the skin and final drilled them to size. Deburred them and clecoed them to the skin. Clecoed the skin to the baffle and ensured that the fit between the spar, baffle, tank skin and leading edge was good. Removed the tank skins from the baffles.
