Craigs RV-8 Web Site
Date:  1-12-2019
Number of Hours:  3.00
Brief Description:  Calibrated the fuel senders
Disconnected the fuel line to the fuel servo and directed the output into a container.
Added 32 cups of 100LL to the left tank, turned on the fuel pump until the pump drew air. Measured 30 cups that were pumped out of the tank before the fuel pump drew air. This leaves 2 cups of unusable fuel in the left tank. This will be the empty calibration point for the fuel system. Then filled the tank until full and entered the second calibration point. Finally drained the system
Repeated the procedure for the right tank and right fuel sender
