Craigs RV-8 Web Site
RV-8
Cowl
1-8-2018
Cowl
Removed the Skybolt interlocking mounts I had previously riveted on.
Mixed up a resin and flox mix and filled in the rivet holes.
Once cured I layed out, drilled and mounted the piano hinge seams on the left side of the cowl look good.
Piano himnge drilled and clecoed
Completed riveting
RV-8 Home
1476
Cowl
141
Engine Baffle
Fuel Tank
532
Fuselage Wiring
Induction system
Windscreen
247
