Spent most of the day redesigning and fabricating the CB-707D bracket that came with the Vans Baffle kit. The original part was deforming the CB-706-A and CB-707A aluminum when it was in place. The new design changed the angle of the bracket by 5 degrees. Removed the three engine case bolts from the top of the engine for the support brackets Installed the new CB-707D aft support bracket as well as the CB-701D forward support bracket using the removed engine hardware and new lockwashers. Torqued the bolts to 96 inch lbs.
