Manufactured mixture control bracket from .060 4041 steel. The bracket mounts using the mounting bolts for the cold induction system and places the mixture cable below the oil sump but above the induction tubes. Torqued and safety wired the mounting bolts I/A/W Titan Engine Assembly Hardware Manual M300 Revision 7 05/25/2011
