Brief Description: Final preparation of left outboard bottom skin
Deburred, dimpled and primed the outboard left bottom skin. Back riveted the doubler and spacer in place on the skin and test fit the skin again. Having the doubler riveted on will make it a little harder to rivet the skin to the rear spar but should not be a big issue.
Dimpled and primed the outboard bottom skin
Back riveted the doubler and spacer for the Pitot Tube mount
