Brief Description: Installed Advanced Flight AOA kit in the left wing
Installed the Advanced Flight Angle of Attack probes in the left wing. Installation was pretty straight forward. I drilled out a brass rivet set to hold a 1/8 dimple set along with a flat bucking bar to hold the female set. Cleaned off the primer inside the wing where the probes were mounted and sealed the probes with ProSeal.
