Brief Description: Checked the wing structure for warp or twist
Finished making and attaching the bottom supports to the wing stands. The outboard end of the wing structure is bolted to the wing stands through the rib. This makes it very firm. The only place to adjust the warp out of the wing is the inboard end which is attached to the stand with clamps. Works very well.
