Brief Description: Preparing the Wing Ribs - Straightened the W-710,
Worked on the W-710, W-711 and W-712 ribs. I found that if I first use the seamer to make sure the flange is square the holding the rib flat on the table work down the flange with the crimper (gently) it works pretty good. Once both sides are done I flip over the rib and check for gaps between the table and the flange and just do a little tuning
