Craigs RV-8 Web Site
Date:  10-19-2007
Number of Hours:  0.50
Manual Reference:  8s6r12 6-1
Brief Description:  Riveting HS411 - Rear Spar assembly
Riveted the HS-411 brackets to the VA146 bearing. Then clecoed the assembly to the spar and drilled the mounting holes using a #21 drill bit.
All we need to do now is mark all of the parts with an electric pencil to finish this section. next we move on to the front spar assembly
first rivet
first rivet
Rivet Squeezer in action
Drilled the holes to #12
