Craigs RV-8 Web Site
Date:  11-28-2016
Brief Description:  Installed main battery cable
Installed the #2 AWG battery cable from the Battery solenoid to the starter solenoid on the firewall. I also ran the #6 AWG power supply from a terminal on the ANL fuse on the firewall to the VP-X Pro electronic circuit breaker. To pass through the firewall I am using the Safeair1 Stainless Steel firewall passthrough kit from Avery Tools P/N SA-05.
wires wrapped with the inner firesleeve
pushing the inner firesleeve into the fitting
Outer firesleeve in position abnd the assemble clamped up
