Checked toe-in / toe-out measurement. Removed tire from wheel, installed axle on gear leg with temporary hardware. Installed wheel on axle Clamped straight edge to wheel face, Marked aircraft Center Line on floor. Using 2 large squares and a tape measure measured from the straight edge to aircraft centerline. left gear had 0.0" delta from end of 42" straight edge to aircraft Centerline Right gear had .032" delta. By calculation this is a angle of .046 degrees well within the required .250 degree maximum toe-in or toe-out.
