Brief Description: Mounted circuit breaker for IBBS trickle charge
Manufactured and mounted a circuit breaker holder on the right side of the battery mount. The location of the circuit breaker mount was normally used for the starter solenoid which on this plane is mounted to the firewall. The circuit breaker is needed to supply trickle charge power to the IBBS battery.
