I started to takel the task of installing the brake lines in the fuselage. I had ordered custom airfoil landing gear from Grove gear. These are shotdrilled for the brake lines. The problem is that the fittings dont quite come out at the holes Vans designed into the fuselage for the brake lines. I dont want to drill new holes unless there is no choice. I have spent hours trying different fitting combinations and doing research on the web to see how others worked this out. So far nothing I have tried or have seen will work.
