Craigs RV-8 Web Site
Date:  9-22-2011
Number of Hours:  3.50
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Horizontal and Vertical Stabilizer
Page 8-54
Trimmed the bottom end of the VS-702 vertical stabilizer front spar (drawing 78)
Clecoed the F-884 attach plate to the aft side of the horizontal stabilizer
Positioned the vertical stabilizer to the fuselage
page 8-55
Marked the 3 bolt holes for attachment of the vertical stabilizer
Adjusted position until the top of the vertical stabilizer to the tip of the horizontal stabilizer were equal. Clamped the vertical stabilizer into position
Drilled #30 through the vertical stabilizer rear spar, F-812-1 bulkhead assembly and WD-409 tail spring mount then final drilled 1/4"
Drilling the splice angle
Cutting the front spar
Drilling the rear spar
