Craigs RV-8 Web Site
Date:  9-13-2011
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Horizontal Stabilizer
page 8-54
Separated the two F-810E Spacers from the F-885 spacer, smoothed and deburred the edges of the spacers
Leveled the fuselage side to side and front to back
Marked a centerline to use as reference on the aft deck
Clamped the horizontal stabilizer rear spar to the F-811B-1 stabilizer attach bars. Put in F-810E spacer under both sides of the HS-814-1 splice angle and used a 3/16 dill bit as a spacer under the center point of the horizontal stabilizer rear spar
Centered the horizontal stabilizer laterally on the fuselage using the joint line where the right and left HS-603PP rear spar channels meet.
Clamped the horizontal stabilizer rear spar tightly to the stabilizer attach bars.
Clamped the HS-814-1 splice angle at both F-810E spacers
Placed some spacers on top of each half of the horizontal stabilizer at the intersection of the HS-608 rib and the HS-603 rear spar channel and verified level. Needed to add one (1) .020 spacer under the right F-810E spacer
Fuselage Leveled
Fuselage Leveled
Horizontal Stabilizer Leveled
