Craigs RV-8 Web Site
Date:  6-12-2011
Number of Hours:  4.00
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Landing Gear
page 8-43
Unstalled the Grove Gear, U-804 inboard main gear attach bracket, U-806-1 inboard wear plate and U-805-1 outboard wear plate uing a 7/16 bolt
Fit the U-803 outboard main gear attach brackets to each leg. Needed to file a notch in the read crossmember for the outboard attach bracket per Grove engineer.
Inserted temporary bolts in each of the U-803 outboard main gear attach brackets and U-805-1 Outboard wear plate to maintain alignment
Drilled a 3/8 hole through the forward floor panel, F-843-L-1 and R-1 lower longerons and left and right WD-822 LG weldments
Macth drilled 5/16 holes in each of the F-822-1 Forward floor panel and WD-813 bolt weldments
Match drilled 1/4 inch holes in the F-822-1 forward floor panel, F-843-L-1 and R-1 lower longerons and F-822-L-1 and R-1 L.G. nox weldments
Removed the gear legs brackets and wear plates from the fuselage , deburred all drilled holes
checking the landing gear measurements
double checking the measurements
Drilling
Drilling
