Craigs RV-8 Web Site
Date:  10-3-2010
Number of Hours:  3.00
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Drilling fuselage skins
page 8-27
Right Side
Match drilled #40 the 3/32 holes in the left F-823 Mid side skins that are common with the F-887 R upper longeron.
Final drilled #30 the 1/8 holes in the left F-823 Mid side skins not drilled in earlier steps
Final drilled #40 the 3/32 holes not drilled in the aft end of the F-826 right and Left center bottom skin
Final drilled #40 the 3/32 holes in the F-842-1 Aft bottom skin
Final drilled #40 the 3/32 holes in the F-828-1 Aft bottom skin
Match drilled #40 the 3/32 holes in the 824-R-1 aft side skins which are common with the F-887-R-1 upper longerons
Final drilled #40 the 3/32 holes in the F-824-R-1 aft side skins that are common with the right F-888-1 aft mid longeron and F-889-1 aft lower longeron.
Final drilled #40 all 3/32 holes not drilled in the previous steps on the right aft side skin
Drilling bottom holes
Side skins complete
Side skins complete
