Brief Description: Adding tailcone to fwd fuselage
Page 8-25
Smooth and deburred the bulkhead caps and the cockpit rails. Clecoed the caps and rails in place after placing the upper longerons Verified the proper positioning of the upper longerons Clecoed the F-848 upper longeron gussets in place Clecoed the Left and Right F-845 and F-846 gussets in place Clamped the upper longeron flush to both webs of the WD-802 L and R engine mount brackets Clamped the upper longeron gusset tightly to the upper longeron Clamped the upper longeron in place Match drilled #30 the 1/8 holes in the F-820 L Fwd side skins through the lower longerons Positioonedthe Auxiliary longerons and match drilled #30 the 1/8 holes in the fwd side skin common to the auxiliary lonerons
