Craigs RV-8 Web Site
Date:  9-12-2010
Number of Hours:  3.00
Manual Reference:  8s8-1r1 12/2/08
Brief Description:  Aft Fuselage Assembly
Page 8-23
Riveted the F-807 Bulkhead assembly parts together
Trimmed, and deburred the F-818B-L-1 and R-1 Baggage rib angles
Clecoed the F-818B-L-1 and R-1 rib angles to the F818-L-1 and R-1 baggage ribs and final drilled the #30 holes
Clecoed and final drilled #40 the F818D-1 bellcrank rib to the F818-L-1 and R-1 ribs
Final drilled and machile countersunk the platenut mounting hole
Final drilled #12 the nutplate screw holes
Page 8-24
Deburred all of the holes in the F-818-L-1 and R-1 baggage rib angles and the F818-L-1 and R-1 baggage ribs
Fabricated the F-857-L-1 and R-1 seat bealt brackets, deburred final drilled and primed the parts
Rivetred the seat belt bracket parts together
Riveted the F-807 Bulkfead assembly together
Deburring the F-818-L-1 & R-1 Baggage ribs
Fabricating the F-857B-L-1 and R-1 Seatr Belt Brackets
