Brief Description: Mid fuselage skins and structure
Page 8-18 Formed the conical bend in the aft section of the F-823-1 L and R skins Clecoed the seat rib subassembly to the F-804 Center Section Assembly and the fwd assembly Final drilled all of the 1/8 holes in common between the F-814E L and R-1 Seat Ramp supports and the F-814A L-1 and R-1 inboard seat rib assemblies Cut the hole for the vent in the F-815A -R -1 and Right F-823-1 Mid Side Skin Clecoed F-815A-L-1 and R-1 forward outboard seat rib angles to the seat rib assembly' Clecoed the Left and Right F-823-1 Mid Side Skins to the Mid Fuselage Assembly Clecoed the F-807 Bulkhead assembly to the F-814B L- and R-1 Aft Inboard Seat Ribs Clecoed all of the armreasts and bulkheads to the F-823 Skins Final Drilled all of the 1/8 holes joining the bulkheads and arm rests as well as the F-805G gussets
Reshaping the aft lower edge of the F-823-1 Mid Side Skin
