Installing rv-8 rear seat rudder pedals Drilled and installed nutplates in the center section for the 8117 L & R brackets Match drilled and installed the 8118 L & R brackets
Page 8-11 Assembled the center section and installed the fwd control mount and seat belt attach lugs. Riveted the Center Section together using the spacer blocks from Ken. Installed the SB750-10 bushings
Riveting the center section assembly
Installed the nutplates for rear seat rudder pedals
Installed the 8118 brackets for rear seat rudder pedals
