page 8-5 Temporarily bolted the 813-1 L.G. Weldments to the L.G. Box Assemblies Match drilled the bolt holes in the weldments removed, deburred and reinstalled the weldments with all bolts and torqued bolts to 25 inch lbs Installed the bolts in the fwd and aft corner angles and torqued bolts to 25 inch lbs deburred the mid-cabin braces and marked the holes not to be riveted on the LG box assemblies Clecoed the L.G. Box assemblies to the sub-floor assembly
Bucking nutplate rivets for throttle quadrant Bracket
