Brief Description: Bottom Stringer, Rear Windshield Bracket and Heade
Cut, fit and glued the bottom stringer to the fuselage. Secured the rear windshield bracket to the fuselage. Tapped four holes in the header tank then painted it with primer. Trim tab bracket also got hit with some primer.
