Brent Connelly - N913BC
Date:  2-2-2013
Number of Hours:  4.00
Manual Reference:  36-06 to 36-07
Brief Description:  Trimmed and attached both main wheel fairings
Warmed up garage with propane heater and worked on fitting and trimming the right main wheel pant. After I got a fairly good gap around the tire and drilled the screw holes for the attach plates, I proceeded to mix up some flox/epoxy and attached both halves to the attach plates. In this cold, it will take many days before I am sure that the epoxy has fully hardened.
Also cut around the seam I noticed in the canopy fairing and used some of the epoxy flox I mixed up to fill the gap. I'm applying heat to it to dry faster (ie reasonable time) After it hardens, I'll sand and finish with epoxy.
