Brief Description: Completed Floor Seat Bulkhead and Control Assembly
Completed attachment of floor ramps by riveting both to the floor ribs and installing all the nutplates. Also installed the control column to the ribs - much easier that expected using a tongue depressor as a tool to help install the washers. Finally riveted the step ribs to the fuselage. Installed all the required snap bushings with Spencer's help and then rotated the whole assembly onto sawhorses in order to being working on the belly skins etc....
Floor ramps installed
Spencer helped with install of step ribs and snap bushing install.
Snap bushings installed - starting to look like a fuselage
