Brief Description: Riveted Bulkhead Assembly Parts
Fit the stub spar receptacle to the wing in storage. Then proceeded to fit and rivet it to the bulkhead. LP4-3 rivets were clearly not long enough to use (must be error in plans) so I substituted some longer AN470 and LP4-5 rivets. Also attached the doublers in this section and the control column mount assemblies.
