Brief Description: Worked on fine tuning Skyview adjustments
Spent a long time making fine adjustments to the contol module in order to get the audio system properly configured. Needed to fix the pilot side jacks as they were apparently grounded and clearly didn't work. Fortunately I had ordered extra radio jack washers from Vans' a while back and after I eventually found them, they were very helpful in fixing the problem.
In the end, was able to get the passenger side headset, com and aux sound all working as desired. The pilot side was not as good. Could get the com working fine. In ICS mode the Dynon works but when switched to isolate mode on the intecom, the Dynon warnings are much too faint. The sound aux system didn't work well in normal mode and even worse when switched to isolate. Will write a note to Vans' tech support to help toubleshoot this.
