BRAD'S WEB SITE
Date:  3-13-2018
Number of Hours:  5.00
Brief Description:  Putting the tail together
Mounted the tail wheel, rudder, horizontal stabilizer and elevator. Trying to install the correct size bolts and hardware so that when I take it apart I can label it in bags for final installation. It's turning out to be a good idea because there was several "do overs" after realzing brackets, etc needed to be added to certain bolts. One issue I'm not too sure about is the travel I'm getting for the rudder. The arms that attach and pull on the tail wheel are hitting the lower bracket and stopping them before the rudder hits the stops. I'm hoping I'm supposed to add bolts to the stops to make up the gap. If so, I'm good. If not, something is going to have to change on the tail wheel steering arms for clearance.
tailwheel steering arm stopped
Rudder is not connecting with stops
Contact before hitting stops
