Brief Description: Wing wiring and wing cable fairleads
I started dabbling with how I'm going to run wires in the wings. I settled on some Lowes light weight plastic tubing that will hold the wire. Also finished up my fairleads inside the wing and drilled out the end lead in the rib so there is more clearance.
