Brief Description: Finished rotisserie front and rear connections
Finished drilling holes for the front fuselage rotisserie mount (and filling with TIG and re-drilling) and bolted on front mount. Was planning for more fabrication to figure out a rear attach that would brace in another place and turned out one simple square tube fit perfect. Just had to drill one hole and bolt and attach with leaf spring bracket. Lucked up and wound up perfectly balanced. Can rotate to most any position and hold with one simple set screw in the rotiserrie.
