Brief Description: Drilled rear of lower engine cowling
Riveted left side of C channel for lower cowling door joint. Worked the position of the lower cowling and drilled the rear of lef tand right sides. Drilled one hole in the front of lower cowling in nose bowl. Holding off on the rest until I can finish the C channel riveting so that it can sit flush. Without the rivets, the cleco's do not allow for a flush fit.
