Finished centering the spinner spacer plate (wooden.) Secured the nosebowl to the wooden spacer with a 3/8" gap betweent he spinner and nose bowl. Had to cut 1/4" metal plate spacers to shim for the missing starter gear in betwee the prop and engine flange. Began to align the nose bowl with the C channel to match the window lower edge lines. Experimented with top cowl placement and hinge for doors. Looks like doors will be a little short so will have to order some .025 sheet for new cowl doors. Very please with the mock up so far. Was a little intimidated about the cowling but I'm figuring it out well! The spinner is larger than typical though. Will have to glass my nosebowl later to conform to the spinner lines.
