I think the wings are about as far as they need to be at this point. The only major job left is to rivet close the second wing. I want to mount it and test everything before I do that. I put the fuselage back on the gear today and will begin to start putting the plane together. Will put all control cables and moving surfaces, wings, tail section in place to make sure everything lines up correctly. After this test and check I hope it will not need to be done again until after it is painted and ready for final assembly. The next major stages to take place are the engine mounting, electrical and dash.
