I had mounted the flaps and ailerons on the 2nd wing but hadn't riveted the rod end bearings in permanently yet. I riveted two large rivets in each arm. I fought and fought to hold a bucking bar under the bottom rivet but couldn't quite get it right. Then I realized I could remove the brackets! I had to take three brackets off so that I could get full access to the rivets. Took a while.
