Brief Description: First flush rivets! Started access panels
Drilled out all of the large access panel stiffeners and experimented to find the right size dimple bit. Installed what I could get to with the rivet squeezer on the panel over the Flap arm. Wasn't a good choice for the first one since there is stuff in the way. Developed a better plan for the others. Will install the nut plates first!
