Planning for plenty of glass (Lexan) for front and rear. Right side looks pretty easy, just going to cut out one current window lower support (where the rear window is designed to end at the bottom.) The left side is a little more tricky since I need to add structure for the fabric to terminate to. Will cut out existing window lower and rear support and create new as lower and a little further back. Also made sure I had something to terminate my inside fabric to and it appears it will work fine. So glad I used poster board to draw it out. I'm sure I would have otherwise did this a couple times with expensive aluminum. Hopefully only once!
