The next step of the Fabric Covering is to re-enforce the top of the Ribs and Rib-Stich all Ribs. Below the Pic's show the tape applied in the first shop and hole for stiches located. The second shot shows those holes "poked thru" the material on either side of the Rib and on both sides of the Stab. This is now ready to be Rib Stiched. In this shop the fabric is attached to the Stab using Poly Fiber Poly Tak.
Stab with re-enforcement tape and Rib Stich locations measured and marked
The Rib Stich locations are not "poked thru" and ready to be Stiched
