I found the necessary parts and spent a couple of hours - looking and reading over the plans to see just where and how it went together. I'm starting to become a bit familiar with his thinking and instructions (not) and I think it's in the right place and as intended. Took 6 hours to do it all, matching parts and joints, fitting, measuring, clamping, then glueing and final clamping. This is the end result. It's located behind the Pilot's (rear) seat back which is on a hinge. For small stuff (like what else would fit there) the Pilot can reach around his arm and under his shoulder to get at some things - I think...if not...It's for on the ground access alone. This is not intended as a Cross Country Flyer.
