Brief Description: Triangle "L's" iinstalled in side of Fuse
Again I'm slow on the update of my log. This entry is the consolidation of 3 brief days efforts. Two hours one day, 3 each on two other days.
I pulled out some cut-off's then bent, cut and made sure all edges were smooth and even a pic of them laying on top of my wing is #1. I then fitted them inside of the fuselage per the 650 designs and installed them. They do indeed make the side panel of the fuse much stiffer.
