Brief Description: Fuselage an Center Wing Spar Jigs 2
After building the Jigs I fitted them to the Center Spar and Drilled and reamed the center holes of the Wing Spar Attach locations in the top and bottom of each side and pin'd them with the 5/16" pins I build yesterday. I then set them up as the spar goes into the Fuse and put the 81 degree jig that I also built and they are a perfect match and fit.
Passenger side Jig in place in Center Wing Spar and 81 degree angle checked and match
Both sides of the Center Spar with the Jigs in place for measurement check
