Spent a lot of time today disassembling the Fuselage that my Grandson and I put together last week. Mounted the lower Rudder Hinge that I postponed last week and again checked all measurements on the Bottom. Deburred then primed the contact points on the side panels and the L's that attach to them. I then clecoed the pass side skin back on the bottom. Checked all measurements and the "square of the side/bottom and rear rib locations. All was in order so I riveted the pass skin then turned it around on the bench for work on the other side before I called it a day. It took an awful lot of time to do these things then clean-up and putting tools away for the day.
Fuselage - pass rear - riveted to bottom with L's riveted too
