No photo's today..Packaged my Tight-Fit angle drill and sent it back for overhaul...the gears stipped out....I came home and got started again on the A/C...This will just log some more time on the Right Wing Assembly...again fitted the top skin and after checking square/level I drilled out the rib and rear spar holes to full/final size. Re-attached the front nose ribs to the spar for next step.
