Brief Description: Fuselage - front floor connect and set-up
Following yesterdays shop/hanger restage and setting up of the Fuselage on steel beams it was time to re-assemble all I took apart to accomplish yesterdays efforts. Put the front and back sections back together and began to set up the next installations prep work. Got the firewall set at the required 77 degrees and secured in place with braces. Bent the floor flange up against the front Center Spar as, I believe, the construction manual calls for and located the position for the rear spar. Set up the longerons for location and initial clamping and checked again all measurements, angles, squares etc....
