Brief Description: Fuselage - Checking Square part 2 for the day
Before I called it a day today I clamped the firewall in it's posiiton and the three rear top bulkheads too so I could again put a square and lazer to the full fuse (so far) to check for racking and square. It alls lines up as it should so - satisfied - I took those items off and put them back in storage until I come to that part of the assembly. Guess I'm getting a bit excessive about square...but better safe than sorry. I now need to get it off the bench and onto bars and saw-bucks so I can make the upper front longeron and some other parts to continue from this point. This will enable me to set the proper angles for the firewall etc as well.
Firewall is clamped - only - in position to check relation to other parts and plans measurements.
Rear top bulkheads are positioned and clamped - only - to check square again
