Brians Pietenpol Web Site
Date:  2-26-2013
Brief Description:  Cut more diagonals and gussets
I spent some more time cutting and sanding gussets in preparation for building ribs. I saw on the Piet forum where some guys use a paper cutter to cut their gussets. It worked ok but I found it easier to get a stack of 8-10 and just run them through my band saw and then touch them off on my 12" disk sander to clean them up.
Sanding gusset for trailing edge of rib
Gusset for front spar
Used paper cutter to cut gusset disks
