Bens RV-10 Site (Non-Active)
Date:  1-29-2012
Number of Hours:  1.00
Manual Reference:  Ch 10
Brief Description:  Tailcone fun
OK...so here's one goof and one good shot...
In shot one you can see that the nutplate mounting on the right side is skewed. Why? Well, the left went perfect. The right? Well, the drill "walked" a har and it no longer lined up with the bolt hole.
Not a problem. I just went ahead and skewed the nutplate, then filled the hole with a rivet. I don't see where this error will cause a problem (and it's not viewable since this is literally in the bowels of tailcone). The actual bolt holes are in the exact right position, so I think I'm OK.
The second photo shows the holes drilled in the tail tie down mounting stock. I have to buy a tap & die set to tap the hole, but there's no rush on that...
